Still having transmission problem...
09civic
So when I bought my car about a year ago, it was having a transmission problem. It is a 95 saturn SL with 75K on the engine. After about a month of having it, the transmission was acting wierd. While im driving and I start to slow down, if I don't completely stop and go to accelerate, it will slip and go into 2nd or 3rd and I have to get up to 45 mph to get it into 5th and it goes back to normal. Once I stop completely, it will go back to normal. This will happen almost daily. I said this on the forum awhile ago and I said if I should flush the transmission, but y'all said that if I do that, it might actually make it worse. Now, when I bought this car, it sat in a garage for god knows how long. So they didn't maintance and the fluid just sat in there. So should I flush it or keep it how it is?
Needs to be opened up bro, no way around it. A fluid exchange won't fix slipping like that. And ya, it could make it worse if anything at all.
eDIT: Also, I'm not understanding you're problem exactly, the transmission should switch to a lower gear when you slow down and go to accelerate again.
I'm not a car expert but my Pontiac had the same problem.i did a partial flush just draining and changing the filter(not flushing what was in the torque) and it ran fine for me.the best way to know if you have a bad transmission is to do what I did and check the magnet on the transmission tray(bowl or whatever you like to call it) and if it's just got dark smudges on the magnet your transmission will be fine.On the other hand if the magnet has metal debris on it your transmissions going bad.
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
added a 32AH bank to my system...... Cot damn! Now we rockin. Voltage staying above 13 wide open!! Just thought I'd update.
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
09civic
09civic
Melbourne, FL
Renzone3
    May 18, 2024
    May 18, 2024
