Stinger SPV70 Battery
  • 4
skdooley
Stinger SPV70 Car Audio Battery
◦SPV70 includes removable brass battery posts for installation flexibility.
◦12v Dry Cell Valve Regulated Lead Acid Battery (AGM)
◦SPV Series Batteries are good for over 300 full discharge cycles.
◦Internal resistance: 4◦20 hour rate: 3.5A/70Ah
◦5 hour rate: 11.9A/59.5Ah
◦1/2 hour rate:87.5A/43.75Ah
◦5 Second Cranking Amps: 660A
◦CCA:875A
◦Watts: 2100
◦Peak Discharge: 1050 Amps 5 Second Burst
◦Weight: 57.3 lbs.
◦Dimensions: (6.87H x 13.75W x 6.5D)
$140 shipped.
Item will be shipped via FedEx Ground in original packaging. Battery has been in my car until today (7/6/11) charging on my car's charging system seeing between 13.8 - 14.1 volts. Resting voltage is 12.6 volts.
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
I was going to check that Vid out the other day when it popped up, and I still, havent watched it yet..LOL. Let me check it out.. Thanks
4
skdooley
skdooley
Roanoke, Virginia, United States
Imtjnotu
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
