stock alt with sax-1200d
  • 3
Yea you should be fine. Just make sure you do the big 3. 160 amp alt is quite big. And I have heard that the new Chryslers actually have some pretty large stock wire as it is... They are pretty efficient amps and I know that they ran a 1500 on stock electrical, (I think it was an Aveo, or some little car), and had it running @ .5 ohms dropping to about 12 volts.
I just put in a 170a alt in my honda with big 3 and a small kinetik hc600 near my sax 1200d and I can stay above 12v at full tilt. normal LOUD bumping you should be fine and stay close to 13.2v Should be perfect
https://electronbeam.com/product/2-0-eb-flex-welding-cable-black/ I bought 25ft of this for power and ground runs and had plenty left to do my...
9
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
728
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
897
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
582
murph
Low for Life
murph
Richmond,VA
Jd377
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
