Stock Bose with Onstar
  • 3
Ruffles810
CarAudio.com Newbie
I have a 2001 GMC Jimmy, I recently had an issue where the CD drive in the stereo shorted out the L&R channels. Which killed the Factory amp, I replaced the factory amp with the exact same model number. I still have no sound. I have tested the wires from the stereo to the amp, audio travels to the amp. I have also tested the wires from the amp to the speakers, audio travels to the speakers. All 6 speakers still function properly and produce sound. I tested the audio output of the radio, the radio indeed puts out audio, even tried an after market radio. Still no sound to the speakers. I manually powered the amp and it does power up, but I still cannot seem to figure this out. I also disconnected the OnStar and pulled the fuse to see if that was shorting something out. No luck. Any help would be greatly appreciated.
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
365
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
617
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
407
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
575
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Ruffles810
CarAudio.com Newbie
Ruffles810
Michigan
Slo_Ride
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
