Stock car speaker issues
  • 3
Kailor
CarAudio.com Newbie
For about a week, each time I get in my car, the sound coming from my speakers varies from which speaker(s) it wants to play audio out of. One day it will play strictly from the rear and others it will only play coming from either the driver side speaker or the passenger. I’ve checked the Balance, fade, etc. and they’re all showing they’re centered. I’m not sure what to do, any help would be greatly appreciated!
If they are the factory speakers, their time may be up. Usually in door moisture causes corrosion in the lead and voice coil solder points. If you have a good spare speaker, connect it to one of the doors for a few days to see if the issue stops.
Thank you, I appreciate it!
Car speakers dont last forever.. Neither do HUs. try a different speaker as stated and same Ohm Load. If it persist.. Its possible it will be an issue with the HU
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
372
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
618
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
418
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
575
Kailor
CarAudio.com Newbie
Kailor
Indiana
audiobaun
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
