Stock Head Unit and aftermarket amps through an AudioControl LCQ-1
  • 1
Droz
CarAudio.com Newbie
To clean up the sound from my stock Tacoma (non-JBL) I know I need a Line Out Converter. But I was looking at also adding DSP for the equalizer flexibility. Would this work and work well to do this: AudioControl LCQ-1 6-channel line output converter with equalizer.
I will be running a
Rockford Fosgate Punch P1000X5 to Kicker CS speakers in the doors and the front dash. Subwoofer as yet to be determined but a single 10" will be all I will use.
Will something else work better than the AudioControl LCQ-1?
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Okay, so basically it’s still a ground loop? But then why would the alt whine go away but the other constant whine stay Sorry I’m just pretty new...
8
Have you contacted crutchfield.com support. They sell modules that allow you to retain the steering wheel-controlled factory features for some...
9
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
343
Droz
CarAudio.com Newbie
Droz
Birmingham, AL
Droz
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
