Stock neon stereo wont play cd's?
1lowmonte
My friend has a 2001 stock dodge neon, shes had since 2001, so no prev. owners. But the question is, that everything worked fine untill not too long ago the cds wouldnt play anymore. Sometimes, it will play the first 2 songs and then say error and spit the cd out. Or like last night you could just hear it turning, and error would show up and spit the cd out. Weve already treid a cleaner that i guess cleans the lenses, so what else can we do, besides getting a new cd player, or what can it be? Thanks ahead of time!
-monte
I would reccomend for both the Neon owner AND the Sebring owner to upgrade the decks. I mean...you are taking out the decks anyway to clean them. Might as well do your sound a favor and upgrade if you can afford to...nothing too crazy..but a nice deck from Best Buy should do the trick.
If that's not an option..
try those lense cleaning kits and try NON-copiedwithout scratches. (Its OK if you don't have neither...I don't either //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
445
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
721
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
460
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
605
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
1lowmonte
1lowmonte
tampa, fl
Bavarian3
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
