stripped screws on sub box
  • 6
Glue over them //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Or get bigger screws to go into the old holes.
Tip: Don't strip the new ones
so between gluing or bigger screws which would be the better option? I was thinking of filling the holes first and then screwing them back in to create a tighter seal.
turn the sub like 15* and drill new holes. use fine thread screws.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Break off wooden matchsticks or kebab skewers in the holes. This usually adds enough wood for the screws to bite again.
Otherwise yeah, bigger screws or fill with something more permanent
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
9
881
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
5
  • Locked
That MRD is a good series of amps ...i may have some extra accesories if you havent found them
8
3K
252
STIorDIE
STIorDIE
boulder, co
hispls
Decebal
    Jun 10, 2024
