STROBE LIGHTS INSTALLATION???
  • 2
davidrh7
Does anyone know how to install "in-headlights" strobes by APC? i get it but i have no clue about wiring and connecting it to switch and battery. I have a box with a red and black wire coming out of it and i have a switch. where do i connect the red and black wires? thats all i need. thanks.-David Henley dhen85@msn.com
If it was APC it should have had instructions with it. That box is the relay. I don't really want to say anything about wiring since it could be different from what I'm thinking. Try APC's website first. After, the relays black wire is the gorund wire, you groud that, the red wire probably goes through a fuse to the battery. there should be connectors on the box, 2 of them. One connector goes to the switch through another fuse, and the last conector should go to the strobe bulbs and they themselves should be grounded. Be careful before you do anything. I've melted a LOT of switches and know that wiring something wrong leads to molten plastic.
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
5
768
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
8
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
davidrh7
davidrh7
Nashville, TN
locomc
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
