sub impedances?
  • 3
Looney_Tune
F**k How You Feel
2,239
Killeen,TX
Ive been looking at two subs...one says dual .7 and the other says dual 1.4 ohms....which one would I need to get for my amp to see a 1ohm load? Are these basically dual 1 and dual 2 or are they what they actually say? I dont think my amp would like anything lower than 1ohm...
yes they are basically d1 and d2
they are giving you the actual resistance of the coils, which some companies round up to d1 and d2.
the d1.4 coil should put you close enough to 1 ohm to run your amp, although some amps won't run at .7 actual ohms
I'd help if I knew enough about it, But some one who does will get on and say the .7's in prallel/series with box rise impedence will put you where you want to be or something.
ok....thanks. My amp is in my sig btw...
228
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
553
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
583
Looney_Tune
F**k How You Feel
Looney_Tune
Killeen,TX
lilmaniac2
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
