Sub makes noise when car turns on
  • 4
afenech
Sydney
I have had a fusion sub in my car for a while. It was initially installed using the high input converter as the stock head unit for my car did not have an RCA outlet. However I recently purchased a head unit and have connected it with RCA cables. However when I turn on the car the sub makes a loud noise. When I unplug the RCA cables this does not happen.
I have no idea what to do.
There's a chance it's the head unit, but it's most likely the RCA cables receiving interference.
Be sure they're not being run alongside any power wires for the amp. They must just be faulty, inferior, or not shielded to begin with. What brand are they?
Is it an initial "pop" or a constant noise? What kind of Hu is it?
The amp is built in, it is one of the active enclosures.
I'm not sure what brand it is.
The Head Unit is a kenwood.
The cable was running along side the power cables so that may be the issue. If that doesn't work I'll just try getting a different set of cables.
Thank you guys
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
430
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
435
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
562
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
685
afenech
afenech
Sydney
afenech
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
