sub mounting hardware
  • 6
Curious as well since I'll be putting a heavy 12" into my off road Bronco. Don't need the speaker pulling out the MDF as it looses its last bit of bite.
I've considered using metal strips with nuts welded on instead of t-nuts. The strips could be held on from the inside with light screws since it is only needed until the sub is bolted down. Think a t-nut on steroids. LOL
screws i have never had any problem of my subs pulling out
Wood strips over time so you really have a limited number of installation/removal of those screws. If you thread in one of the inserts I posted you now have metal machine threads...which should last quite a bit longer
have taken my subs in and out 10 + times and they still get tight when you screw them in i dont have any holes that are stripped out. But i know what you are saying
So you have to drill holes them thread those in because that seems way better then just screws
Yes, you drill a larger hole and thread in those inserts. You then never have to remove those inserts and you now have metal threads and you can just use regular bolts. I will say it may not be a bad idea to put a dab of glue on the outside of the inserts because if you tighten the bolt too tight, you'll end up backing the insert out when you go to take the bolt out, then that is a PITA. It's happened to me once or twice and I just cut the insert off the bolt with an angle grinder...
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
265
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
575
blackdrag450r
blackdrag450r
wisconsin
DonH
