are you doing ported or sealed?Anybody?
sub facing up, port firing to the drivers sidealso for a ported should i face it towards the front or back in the trunk?
Im doing ported, already have the box though, it has the sub and port both forwardare you doing ported or sealed?
if ported i would do sub up, port facing the drivers side wall. so put the sub on the far top side of the box, then put the port on side of the box on the drivers side. should do well
---------- Post added at 07:58 PM ---------- Previous post was at 07:57 PM ----------
i see..... even so it should still do ok. the way i was saying is a good way for SPL. what equipment do you haveIm doing ported, already have the box though, it has the sub and port both forward
thats should work.Im doing ported, already have the box though, it has the sub and port both forward
ever tried sub up, port to driver side? had a friend pulling 152dbs on music at the headrest with a 2 12s with his box that way. we have a girl on our team doing 148s with 2 12s on music at the headrest and burping 150s. she has her box that way as wellI have a 99 Dodge 1500 extended cab and I've always had the best sound quality and sound pressure for a single woofer with the woofer forward, port upward and the box all the way to the right. e.g., port firing up in the passenger's side rear corner of the cab.
In a cabinet that had the woofer and the port on the same face, I would run the box in the same location but with both firing up. I've also had a number of fourth and sixth order bandpass enclosures in this truck and again, ports up always sounds better. I recently built a t-line for a JBL 10 and the terminus (port) and woofer are on the same face. That box is as wide as the back seat but not very tall at all and it performed better with the woofer and port up as well. And.. both at the right (passenger) side.
That's been my experience and I've owned this truck since it was born and, I've had too many boxes in it to count.
