Sub wires BURN
thanks alot everyone. im going to buy some brand new wires next month i dont drive my car now because im studying for dental school but thanks for the great info!
...and your DC low voltage landscape lighting //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There it is! Banana plugs could very well be your problem. If you are using those Alpine ones for jumpers and wiring to a certain load, pull the splines out on them with a tiny jewelers screwdriver as you want a TIGHT fit, but I don't like plugs for a reason. Or, rather much better yet, use more cable instead eg: say you have two DVC 4ohm drivers, and you want to run 1ohm by paralleling each driver's coils and then both drivers, use four runs of cable from the enclosure terminals (only if it is up to par on handling the power, if not go directly) or amplifier terminals. The idea is to split up the current upon more surface area of cable essentially. When running a decent amount of power, you want the most direct runs and more cable to reduce heat build up and voltage drop, not that it's a big deal with the output side, the latter applies more to power runs. You do not want to switch mediums that the power is running through though either way. So, even if you have some quality Knu cable, properly installed into your banana plugs, that still doesn't mean that it'll take the power especially if loose. Bad connection = heat.
Sorry I sense some brevity in this post, I'm paying attention to a ridiculously long Summer class and surfing forums. Ah, I can do this, just a bit to go, four hours has almost passed by :p
sounds good. just to be clear, only remove the jumpers when you have a speaker wire for each voice coil. It may be obvious to some, but not everyone.
I don't know about the charts and ****, but I do know that 8awg CCA won't take 10k.
Basic Car Audio Electronics
Scroll down to section 16. Wire
The very first calculator is for speaker wire. Just need to know power output per channel, wire gauge, wire length, and impedance and it will tell you if it's adequate.
OK. UPDATE-
I put all 10 gauge knukonceptz wiring for the entire subwoofer wiring setup 2 dual voice 4 ohm subs wired to 1 ohm with the jumper cables being 10 gauge as well, and the wires from the sub right to the amp directly without an enclosure connector.
playing jay Z - CROWN- or any bass heavy song on level 30/40 my sub gets SUPER HOT and i smell it burning a little bit.
Any ideas?
Crescendo bc2000 amp on around 1700 watts (from gain with DMM) in a 40hz ported box by mobile enclosures. Now, im not sure if its because the box is VERY small that it is suffocating it or making it work EXTRA hard to make it make power.
Any ideas guys?
this is the box
Aren't Type R's only rated for like 500-600? You're giving them 850 each? Maybe you're just overpowering them. I remember my R's back in the day used to get stinky on just 1200w.
no. these are rated 1000 rms these are the latest version type r's from 2012. the 2011 type r was rated 600 watts rms but new ones 1000rms
Have you ohm-ed out your voice coils individually to see if you have a shorted VC?
nah. nothing is wrong with the subs they play normal. just sometimes when playing REAL BASS HEAVY songs i could smell it while playing at like volume 25-30/40
im wondering if its because my box is too small so its suffocating it? im throwing a lot of power in that small box
The box is too small and tuned too high, and you're probably sending a clipped-all-to-hell signal. When playing low notes on 40hz tuning you're going to beat the hell out of your subs
Also I got a bunch of 10ga OFC speaker wire for about 45 cents a foot from Knu a while back, but I'm not sure if it's still on sale.
Clipity clipity = smelly subs.
so bigger box tuned 34-36hz plus oscope calibration is what i need?
That would probably solve a lot of your problems. Those Type Rs will take 1k of clean power no problem in the right enclosure, but playing under tuning or sending them distorted power won't end well
193
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
535
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
566
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
661
RoYALbLUE08
RoYALbLUE08
NYC
RoYALbLUE08
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
