Subs & amp have $400
I have a Diamond Audio 15" D6 Dual 2ohm ( the good ones with 3" VC ), and a Eclipse 15" SW 8152DVC ( 3" VC also ) TC based subs, work excellent in small sealed boxes,or get crazy in vented.
GET THE DIAMOND. We had a D3 15" in a sealed box with 400rms going to it and it pounded.
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Giovanni15
Giovanni15
Greeneville, TN
BrownVanMan
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
