Subs amp going into protection mode after turning it up HELP
  • 2
Jeano221
CarAudio.com Newbie
So I’m having a issue with my amp going into protection mode after turning the radio up, it’s a stock bmw radio and the positive and ground are 11.90 when cars off and 13.60 when car is on, I switched amp snd still did the same thing... don’t know what else to check. Do if anyone can Help me out on what test to do or where to check..
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
939
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Jeano221
CarAudio.com Newbie
Jeano221
United States
delete
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
