Subs and Amp to Factory Deck HELP!!! 07 Chevrolet Impala
  • 2
mstan2221
MI
Hi i saw a person that had thier amp and subs wired to thier factory deck on the same car i have. Its an 2007 Chevy impala and im trying to figure out how they did it. Any help is greatly appreciated thanks!!!
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
984
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
mstan2221
mstan2221
MI
Falcons
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
