subs making burping noise
Did you take the sub out and look at it? Personally, I've seen burping in 2 scenarios.. clipping/bottoming out, or what sounds like burping, when a tinsel comes loose and slaps against the cone.
nah they're brand new..
so i'm sure its clipping.. i guess i'm underpowering them...
so what could i do? jus turn the gains down and make sure they don't clip?
are you sure you're not overpoering them? The same thing happened to me. It's hard to believe you're underpowering them if it only happens when the gain is all the way up. Check and make sure your running enough power.
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
988
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
697
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
deeza
deeza
t dot
rocca_dogg
