Subs stopped working
  • 2
ForAQuickFix
ok so sometime last month my sub-woofers stopped working, they were working fine until about a week or two after I wired them parallel (Two 4 ohms subs - to two ohms). I checked the fuses on the power wire and amp, tested the amp everything seemed fine. Come to find out the sub-woofers were blown. I bought a new amp (before I tested the old one(dumb)) and bought new sub-woofers wired them to 2 ohms in my old box. and when I cut on the amp I still get nothing. amp is brand new and powers on- sub-woofers are brand new- I am using a factory head unit with an LOC converter.
Where do I start troubleshooting from here?
the plastic terminals in the box can melt and cause a loss in connection. if you wire the subs out of phase you won't hear much.
how were they wired before they were wired in parallel? series?
double-check that the input to the LOC isn't out of phase. disconnect one RCA from the amp input.
use a DMM to measure resistance of the woofer coils while installed in the box (measure at the speaker wires at the amp disconnected.)
RCA can cut out.
The issue may be the sub box, not the equipment. If you got them prefabricated, chances are you got the wrong size an tuning.
4
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
172
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
437
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
592
ForAQuickFix
ForAQuickFix
Detroit
keep_hope_alive
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
