Subwoofer First install sound problem
  • 4
Not a lot of room looks like. Take what you can get ya know. Its nice to have some type of sub stage for sure.
Storage is actually pretty big ( but not big enough for an enclosure that's mounted on the door because it closes in an angle believe it or not but I build one of those too.. ) fits a back pack etc and it's on both sides behind both seats but didn't want to sacrifice it. .. Plus the amp for the front speakers is under a board in the same storage and with a custom enclosure I would have to move that one or both amps into the other storage ...so even more loss of storage. So I think this is the best solution over all. But def. not a lot of bass... at best I would say it supports the low frequencies. ( But that's also because it runs outside not inside a closed vehicle) .
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
7
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
11
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
mactube
CarAudio.com Newbie
mactube
Los Angeles
mactube
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
