subwoofer help please
  • 1
Jimg
CarAudio.com Regular
217
13
amplifier that will be used us acoustics mike 1500 rms tru rating at 1 ohm 1000 w at 2 ohm
car that will be used 2012 ford mustang
I want to subs to be front firing into the car, I want to build a amp rack in the trunk and still have use of the spare tire access
budget I would like to stay with is no more that $450 for the total subs
music types, mostly rock music, but would like to play a some bass every once in a while.
measurements will be a max for the enclosure ( outside measurement ) of 34 inches wide 11 inches tall 12 inches deep using 3/4 inch material
so about 2cf internal space give or take a little
thought about running two 10 inch subs or using three 8 inch subs
I have looked at parts express Dayton HO or the Ultimax series in a sealed enclosure
but I am open to other options
I know ported enclosures can get a little more db's than sealed, But I figured with the amplifier I am using sealed would not be an issue with the power it has.
giving the limited space , using 1500 watts RMS what would you go with?
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Jimg
Jimg
Jimg
