Subwoofer help?
  • 2
fair_bear
Hi i was wondering if anyone could help me....
i have a pioneer ts-w308 D4 12" sub runnin at 2 ohms.
My amp at 2 ohms only pushes out 265 wrms and at 1 ohm pushes out 500 wrms
i want to either change the sub to a ts-w308 D2(to run at 1 ohm) or add a 2nd ts-w308 D4(bringing both the subs to 2 ohms then bridging them to run at 1 ohm)
please advise me on which would be a better option and how much louder would it be to run 1 1ohm sub instead of two 2ohm subs..
TS-W308 D4/D2 (450wrms subs)
thnx alot excuse my english and my questions for i am a noob at this:confused:
would actually be louder to get two subs puttn them at one ohm. its twice the surface area than one sub. for the same amount of power, two twelves are gonna hit harder than one
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
944
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
fair_bear
fair_bear
south africa
ShakinDaBlock
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
