Subwoofer Help
AcuraTL
Burnaby
Hey guys I just recently bought a car a few months ago. I bought a 2012 Acura TL Elite SH-AWD. Looking to put 2 12s that are around 600-900RMS. I have a list below and your guys opinion on deciding on what to get. Looking to make the purchase tomorrow online for cyber Monday
JL Audio W6
Rockford Fosgate P3
Kicker CVX
MTX 7512
Alpine Type R
DC Audio Lv3
Sundown SA
Digital Designs 2500
My goal is to have the loudest setup I possibly can with the subs I mentioned above. They will be all using the same amp which is a Rockford Fosgate T1500BDCP. Mylows10 you said any of the bottoms 3 does that also include the Skar VVXv3? and why would you go with the bottom 3? If those bottom 3 weren't there which mainstream brand would you go for?
Does voicecoil size matter? All the subs have 2.5" voicecoils while the DC one is the only one that has a 3" voicecoil. I was sort of leaning towards the Sundown SA or the DC. Which would you prefer.
if you don't have much space for a box, id go with the DCs, if you have more space for a box I'd go with the sundowns. You'll be happy either way as long as you build a box to spec or have a box built
I would take a 3" coil over a 2.5" coil any day. Thermal capacity is higher on a 3" coil. Yes the ex subs need a small box. All the other subs mentioned will need 2^3 per sub or more any of these SUVs will work tho being loud is gonna depend on the whole build. Not just subs and amp What's your electrical look like ? As this will help. Also have you deadened the trunk ? This again will help
Well its a 2012 Acura TL SHAWD so the trunk isn't that big cuz of the AWD system. Electrical is stock for now but will do the big 3 and have a XS Power batter up front and will have a small XS Power battery in the back. So the DC will will need a total volume of 2.5 cubic feet or bigger? and the sundowns will need a 3 or 4 cubic feet box?. My top three are DC LV3 with the upgraded parts, Sundown SA, and the Type R cuz there really cheap.
Forget the type r. The sa subs will need 4 cubic ft for them to sound good. The dc subs will need 3cubes You'll also need a big 3 kit and 0 gauge wires
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
939
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
AcuraTL
AcuraTL
Burnaby
AcuraTL
    May 19, 2024
    May 19, 2024
