Subwoofer Reccomendation (sorry in advance lol)
The Pioneers have a high Q and VAS, which means they need a big sealed enclosure. They aren't bad subs, but unless you're getting them cheap, I'd look elsewhere.
Just making sure I understand this correctly, again trying to learn as much as possible here. So because the speaker has a QTS, it means that is is less "springy" and better suited for a sealed enclosure? Also is the VAS the optimal enclosure volume? And you mentioned if I found the Pioneer cheap. They're usually $150-$160 everywhere but Sonic Electronix has them on sale for $90, worth it, or would y'all still reccomend something else?
I haven't heard those Pioneers, so I have withhold my opinion. What I don't like about them is the lack of xmax.
QTS typically ranges from ~.25 to .7. Generally speaking low QTS means the sub's low end needs to be augmented by a port. VAS is the sub's compliance and indicates how big of an enclosure it will require. QTS and VAS work together to calculate the enclosure size the sub will need; the higher the QTS and the higher the VAS, the bigger the enclosure. That said most manufactures give you a range of enclosure sizes for their sub and most of them usually pretty good, but you generally want to stick to the high side of their recommendations. OTOH, there are whacky subs/companies that sometimes put out a enclosure way too small for the sub - ie Earthquakes shallow subs.
I haven't heard the Pioneers. Pioneer never really puts out crap, but it's kinda hit and miss on their subs if they're good are just average. I've run older Type S subs and really liked them. I've never heard an Incriminator or SSA sub that wasn't impressive. ID subs seem to always sound really clean even if they lack the impact of other brands.
The SoundQubed subs I've heard always struck me as loud, but not the cleanest sounding.
How is the sound quality on these? I'm not some audiophile, but I'm a musician (not some SoundCloud dude, like the entirety of my income is from music) so I have a little better ear than most. Not doubting your reccomendation, just don't have any expirience with these subs.
Run with these and thank me later.
SSA's store has some Incriminator I series subs for really cheap. It's the previous version and only one VC configuration is available, but the price is great. Cerwin Vegas Vega series (red surround) are pretty good for the money.
Only problem with the old model I series is they recommend a much bigger box than the current I series. I actually have a pair bnib deciding what I want to do with them
Id also take a look at Ground Zero to see if you may find an amplifier that meets your needs.. Maybe even Sound Digital...
18
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
410
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Aidan Fox
CarAudio.com Newbie
Aidan Fox
Clifff150
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
