SOLD Sundown 3000d must sell asap
grizzjwill
Beatin down the block
1,230
nashville,tn
I have a sundown 3000d that I have ran for the past month. Im stuck out of town and I need to sale this to make it back home. I have a few refs on here if needed. The amp works perfect and I would give it 9/10 cosmetically only because it has been mounted. Im asking 510 shipped if you buy tonight. Specs are listed below.
SPECIFICATIONS:
* 3000 x 1 watts @ 1 ohm
* 1600 x 1 watts @ 2 ohms
* 800 x 1 watts @ 4 ohms
* 0.2v - 6v adjustable input sensitivity
* 10 Hz - 350 Hz Frequency Response
* Greater than 90 dB S/N Ratio
* 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
* Linkable to another SAZ-3000D for up to 6000 watts @ 2 ohms
* 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
* 10 Hz - 60 Hz adjustable 24dB Subsonic Filter
* 0 - 180 degree adjustable phase shift
* 0 - 18 dB adjustable bass boost with 45 Hz center frequency
* Wired Remote Control unit included
* 300-amp external fuse required
* 23.4" L x 9.9" W x 2" H
unbelievable price!//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif sounds too good to be true! it shouldn't last more than an hr here:D
Well im bumping this again. I really need it gone. I have a few refs on here that I listed on page 2 adn there is a couple more I cant think of.
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
674
10
grizzjwill
grizzjwill
nashville,tn
kmanian
