MitchZ 10+ year member
My setup:
2 Kinetik HC2400's in the back
Shurican BT80 or BT60 under hood
2 strands of 0 gauge front to back
Big 3 done with 0 gauge
320A iraggi alternator
Soundstream xxx 18
2 Sundown SAZ2000D's
I am running these amps strapped at 1 Ohm.
Heres the problem...
I can charge the batteries to full, drive around bassing for 15-30 mins, then the amps will start a high pitched whine that gradually gets louder. Usually when I hear this, I pull over and pull the remotes out so I dont blow an amp, drive home and charge the batteries (they take about 45-2hours of charging on a 2 amp trickle charger to get fully charged again), then I can put the remotes back in and start bassing again.
Today for the first time one of the amps went into Protect mode, so I turned the car on/off again and the amps were doing the same whineing, so I pull the remote out and drove home.
First thing that comes to mind is maybe one of the batteries is dead.... I pulled each battery separately, and both kinetiks have never needed to be charged, while the front battery always needs to be charged when this happens. I used to have a stock battery under the hood, that I replaced with the shuriken because I thought this stock battery was the problem.
Any thoughts or suggestions?
Right now I'm thinking one of the kinetiks is dead, even though it never needs to be charged...?
Soundstream xxx 18
