Sundown E-12 box help
  • 3
EC11
I got a sundown e-12 and i need help on what box to buy. I'm going to give it around 500 rms and i have a Altima. I wanted to go sealed because i want to keep it small, but i know ported will sound better/louder. How small could a ported box be, with the sub still sounding good. Or would it be possible for a sealed box to sound good.
What Buck said. Plus, Sundown recommends as small as 1.5ft for a ported box, which is only a little over half a cubic foot larger with displacement than the 1 cube sealed recommendation. So in the end, not much larger physically but a lot larger audibly.
ok thanks for the help. i mainly listen to hip-hop. So a 1.5 ft ported box being the best, could i get a pre-fab or should i get a custom made one.
You should get a custom one. I would like to see something like 2 cubes ported with a 4" aero, that'll sound great.
To be clear, I didn't say a cube and a half was best, I said it was barely larger than the sealed recommendation. Like Buck said, 2 cubes would be better (probably best for that sub) and an aero port is worth the cost.
Let him build you a box. From what I've seen, he has the knowledge to design and build a quality enclosure for you.
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
506
EC11
EC11
Cincinnati
bbeljefe
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
