Sundown SA-12
Magnum099
I am looking to get a new subwoofer for my daily driver, and I am leaning towards getting one SA-12. I have a couple of questions though, mainly for people who have experience with the Sundowns.
1) Ported or Sealed? I know ported is generally the choice for the Sundowns, but I was just curious if anyone had any experience with them sealed. I like the bass punchy and tight, but I also want it loud.
2) What amplifier? My budget for an amp is $200 or less preferably. I don't want to go over 700 watts though. I was looking at the Alpine MRP-M500, Pioneer GM-D8601, and the Rockford Fosgate R500X1D. All of these put at 500 watts rms at 2 ohms though, and I wasn't sure if that would be enough since the sub is rated at 600 watts rms.
3) Would it overpower my mids and highs? I have Rockford Fosgate Prime speakers with an Alpine 4 channel amp pushing 40 watts rms per channel right now. Would I need to consider an upgrade, or would it matter?
Any input is appreciated. I am open to other suggestions for subs though, as long as they are around 400-600 watts rms.
Thanks!
I can't do 1000 watts. The wiring is 4 gauge and I don't want to have to get a upgraded alternator. Should I consider a different sub? I want to run between 400 and 600 watts rms to the sub.
For a 1K system, you should be fine with a decent 4 ga wire - and a H/O alternator definitely isn't mandatory.
For the box I would go ported, and you can just tune it a little higher. As for the amp, the AudioTechnix amp listed above would be a good choice. For electrical I would just get a decent agm battery, do the big 3, and get 4 gauge for your amps.
What would be the advantage of getting the AudioTechnix amp over the ones I listed? The ones I listed put out 500 watts rms whereas the AudioTechnix only puts out 400.
just depends on your sub. If you get a dual 4 ohm sub, you can wire it down to 2 ohms and the amps you listed would be good.
The Pioneer 8601 amp is not good if you are running ported due to it not having a subsonic filter. Running sealed on that amp is recommended.
If you get a dual 2 ohm sub, the Audio Technix puts out ~600rms at 1 ohm which would be perfect for that sub
I would go with a sound qubed 750.1.. Get a dual 2 sa12wire that bish to 1 ohm and tune it at 32.. Also keep the box around. 2 cubes after displacement, if not 1.75
Im a newbie to car audio so take this for what its worth but i just installed a sundown sd-2 12d4 (shallow mount version of the sa) and an Alpine 500 amp wire at 2ohms. I got the amp off amazon for $120! I dont have much space in the truck so its in a .96 sealed box. The setup Jams. not really rattling bass but loud clean sounding bass!
P.S I learned the hard way..set your gain right first thing and dont use a bass knob usless its really turned right..
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
424
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
3K
Magnum099
Magnum099
Tennessee
Jeffdachef
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
