Sundown SA12 port area?
Port?
  • 3 inch aeroport
    Votes: 0 0.0%
  • 4 inch aeroport
    Votes: 2 50.0%
  • Stay sealed
    Votes: 2 50.0%
  • Total voters
    4
  • 4
dont cram subs into were they arent supposed to be.
Sub is already there in a box. If I can fit it, I'm gonna add onto the box. But that's gonna be a couple of weeks. I'm ready to port it now and go get metered again. 130.7 legal ain't cutting it for me.
[quote name='Brian21699']Will a 3 inch aeroport be enough in just under 1.5 cubes? Or do I have to use a 4? I would have to cut out some of the plastics of my truck to put a 4, but a 3 will fit perfect. @sundownz[/QUOTE]
port takes up space, sub takes up space. You are not gonna get adequate port area nor low enough tuning to make it worthwhile. You Might gain a tiny bit but you will sound peaky. To be honest your current box is only good enough for a 10. As in a 10 will get louder and sound better in that box than a 12.
I already accounted for the sub and the port will be external. I'm probably gonna end up swapping to a 10, but for now I have a 12.
It is an L port. You might as well add three 45's. Add one by the leg of the L and the two that I showed you in my other post.
6
There are lots of different programs. Winisd gives you the basics
25
4K
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
414
Brian21699
Brian21699
Vancleave, MS
Brian21699
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
