Sundown Sax-1200d
n3w_3ra
Sundown Sax-1200d
8.5/10 Cosmetic 9.5/10 mechanical (used)
Rated power output
----RMS power, 2 ohm linkable/dual mono
2160W x 1CH
----RMS power, 1 ohm mono
1200W x 1CH
----RMS power, 2 ohm mono
720W x 1CH
----RMS power, 4 ohm mono
360W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 3
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 310(L)mm
I bought this amp about a month ago from another member on the forum. I hooked it up for 2 days, and then sold the subs in my car. Only reason I am selling is I saw the new crescendo amp and my alternator is too small, So i need a very efficient amp.
When the price on the crescendo goes up I will take this down.
215 shipped
Sundown Sax-1200d
Rated power output
2160W x 1CH
1200W x 1CH
720W x 1CH
360W x 1CH
T.H.D @ 4 ohm
Fuse rating 40A x 3
215 shipped
bass knob included?
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
506
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
3K
n3w_3ra
n3w_3ra
S Florida
duhamell69
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
