Sundown SIA-1750d - any good?
  • 3
Baconbitz121
CarAudio.com Newbie
So I just pulled the trigger on a sundown SIA-1750, which will be a replacement for my Skar RP-2000 that recently kicked the bucket. I was overwhelmed with all the options available, but I didn't want to spend an arm and a leg. After all the crap I've heard about Skar, I'm pretty confident I'll be more than satisfied with the sundown - the bar is pretty damn low :LOL:.
Does anyone have experience with the SIA-1750 or anything from sundown's SIA line? From what I read it's an updated version of the SFB line, which has low voltage protection that protects it from the shortcomings of being a full-bridge amp. I came across the kicker CX1200 for around the same price of the sundown. I had a 600w kicker amp on my old setup that I really liked, so that's why I was eyeballing the kicker CX1200. My plan for the sundown is to use it at 4ohms which it's rated for 1250w VS. the kicker that's 1200 @1ohm. I'll most likely keep the sundown.
I'm just curious what y'all think about the sundown and comparing it to the kicker. I also have no clue about the hierarchy of different brands. Put my mind at ease please!!!! lol
A nephew has that amp on a pair of SA10 classics. The truck is a diesel with a beefy OEM alternator and a small AGM secondary battery. It has been about a month since installed and seems to be holding up well. It is definitely powerful.
  • Locked
The picture needs a piece of paper with your name and date in it, forum rules not trying to be a dick.
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
469
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
Baconbitz121
CarAudio.com Newbie
Baconbitz121
Virginia
chillin
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
