Tang Band 6x9 subs (which one?)
  • 2
anks106
16
USA
I am looking at these two, is the more expensive one worth the price difference?
http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=264-837
http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=264-864
Specifications as given:
Specifications: Power Handling: 90 watts RMS/170 watts max *VCdia: 1-1/2" *Impedance: 8 ohms *Re: 6.5 ohms *Frequency range: 35-350 Hz *Fs: 35 Hz *SPL: 87 dB 2.83V/1m *Vas: 1.34 cu.ft. *Qms: 6.05 *Qes: .37 *Qts: .35 *Xmax 7mm *Dimensions: A: 6-1/2" x 9-1/4", C: 4-3/16
vs
Specifications: Power Handling: 80 watts RMS/160 watts max *VCdia: 3" *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 40-350 Hz *Fs: 40 Hz *SPL: 88 dB 2.83V/1m *Vas: 1.65 cu. ft. *Qms: 2.29 *Qes: .28 *Qts: .25 *Xmax 5.5 mm *Dimensions: A: 6-1/2" x 9-1/4", C: 2-3/16".
Also, would I experience any problems in putting these in the rear deck of my car? It is a pontiac grand prix if that affects
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
  • Locked
The Orion Concept 97.2 was the worlds first stand alone digital 30 band 2 channel equalizer. The Orion Concept 97.2 processes all the equalization...
I have an extra pair of these, NIB, $100 shipped!
14
3K
Excellent!! Looks to be in tact. It will be a workhorse for you man
40
5K
anks106
anks106
USA
anks106
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
