Tara amp questions
  • 2
mml
Thinking about using 2 x TS400X4, 1 in 4 channel for mids and tweeters, and 1 bridged for midbass.
Also thinking about using a bass 1200 - 1 ohm for subs.
Not expensive and reviews look decent.
I have a Stinger heigh10 head unit, the crossovers are not usable. I have an MS8 that I was considering to implement. That or an active crossover using the head unit for time alignment.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
226
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
430
mml
mml
ottawa, canada
