FOR SALE Taramps md3000.1 1 ohm new
  • 1
mclerico1983
CarAudio.com Newbie
Tampa
Price
$210
Condition (1 worst - 10 best)
10
TampA
Brand new
210 shipped
TECHNICAL INFORMATION
OPERATION CLASSClass D
NUMBER OF CHANNELS01
MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS
@ 12.6 VDC - 2 OHMS: 1920W RMS
INPUT SENSITIVITY220 mV
SIGNAL TO NOISE RATIO>90dB
FREQUENCY RESPONSE10Hz ~ 18KHz (-3dB)
CROSSOVER HIGH PASS (HPF)10Hz ~ 90Hz (-12dB/8ª) Variable
CROSSOVER LOW PASS (LPF)90Hz ~ 18KHz (-12dB/8ª) Variable
BASS BOOST0 ~ 10dB (50Hz) Variable Frequency (35 ~ 55)
EFFICIENCY79%
INPUT IMPEDANCE15K Ohms
OUTPUT IMPEDANCE1 OHM
PROTECTION SYSTEMShort-Circuit to Output, Short on output compared to GND, Low impedance at output, low/high supply voltage and Thermal protection
MINIMUM SUPPLY VOLTAGE9VDC
MAXIMUM SUPPLY VOLTAGE16VDC
CONSUMPTION AT REST1.0 A
MAXIMUM MUSIC CONSUMPTION150 A
MAXIMUM CONSUMPTION IN SINUSOIDAL SIGNAL300 A
DIMENSIONS (WXHXD)8.98" x 2.76" x 8.58" (228 x 70 x 218mm)
WEIGHT5.5lb (2,5
kg)
EAN7898556844628
Was Photo Included
  1. Yes
Was Note Included
  1. Yes
The ds has more power...it's rated at 12.6v and the ts at 13.8v... I had the the ts400x4 though and it a good little amp
885
Oh boy do I know too much about that... 20 years as Type 1. :poop:
13
mclerico1983
CarAudio.com Newbie
mclerico1983
Tampa
mclerico1983
Latest topics
