TC Sounds Sub?
  • 4
SoCaL081
50
I've had a few 12" Eclipse subs such as a SW9122DVC, SW8122DVC & a SW8102DVC which from what I hear were made by TC Sounds but I got a actual TC Sounds TC-1000 12" sub that is a single 4 ohm I believe but can't find any info on it. The sticker on the magnet says it was made in 2007 but I really want to get the specs on this thing. I also wanted to see if this TC-1000 is any better than this Eclipse SW8122DVC I have right now. Hopefully someone can help me out. Thanks in advance!
The tc1K 12 is more sq oriented, the eclipse drivers were a bit louder and more warm sounding thanks to a bit more q and a higher fs. The tc1K drivers are very box dependent thanks to their higher than average ebp and power has to be more closely monitored becasue Xmax and Xmech are dangerously close together similar to the way it is on Xbl2 motors. I've had every size of tc1K and in several versions. The Salk, The AV Stryke, The eclipses, the soundsplinters, the IAS's etc. The TC1K was very sound signature similar to the tc2K which was also a low q woofer.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
4
601
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
SoCaL081
SoCaL081
audio_phill
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
