Terminals on a box...?
  • 2
SpeeDFX
I want to build my enclosure for my 2 shivas...and I know I need to put terminals on the box... I want to put terminals on 2 sides of the box so I can orient the box differently if I want to (without having wire trouble). My questions are.... do I need a terminal for each sub? is it ok to have 2 terminals wired up to each sub (for easier accesability if I want to turn the box around)? and WHAT kind of terminals should I buy and use?
Originally posted by SpeeDFX I want to build my enclosure for my 2 shivas...and I know I need to put terminals on the box...
don't need to could just drill a small hole an run wire out of the box
well only of you need to access each sub for wiring in stereo
sure
and WHAT kind of terminals should I buy and use? ]
got to radioshack and get some or crutchfield ----anybrand
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
725
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
SpeeDFX
SpeeDFX
Altadena, CA
chris229
audiobaun
    May 19, 2024
    May 19, 2024
