Tesla Y Sub Decision
  • 5
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db efficiency, tuned to around 25-30hz, as your Vb will be around 1.25 cubic feet
Another REALLY good option that is actually optimized for that enclosure, ported at around 30 hz is this at $359
@ $229, my personal fave for that as a sealed box (you'll hit into the mid to low 30's with cabin gain) is the Focal 33v2. Tight articulate bass, fast atack, never anything but sold musical thump. Stuff the cavity with 1.5lbs of Acousta-stuf, beautiful sounding driver. I run two of them myself.
The Kicker really isn't in the same league sonically. I used 15" barg grills to facilitate temp protection of the driver. I have these on the way. When you click on the link, select the Doxquzme 12" link and it would be customer made for that 13" Focal ub.
Maybe I'm asking obvious questions but do you have a shop and could you send me a link I definitely don't mind supporting helpful people.
I didn’t want to mess with my daughters EV, so I just made a small stand alone with 6x9s. It’s around 75 watts rms and fairly loud actually. Real...
8
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
509
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
546
mr b
mr b
Los Angeles
mr b
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
