Testing subs with dmm, nothing
brafferty
idaho
I invested, and when I turn it on the ohms setting, it reads one constantly, unless I touch the leads together, than they get a reading, but when I put it on my sub or speakers it reads nothing; I'm sure it's a simple mistake since it's my first time using one.... I have it set for ohms at 2m, but I have tried 200k, and 20k and nothing
Where do you have the leads placed on the meter itself? Is there just two plugs
Sent from my Nexus 6 using Tapatalk
No there was 3, one labeled com where I put the black lead, and then I put the red one on the one that had the ohm symbol by it
I'd say fault in the meter, a 1 means value is overflowed (too much) but you went from 200 to 20k with no change.
I am, but it reads everything else I try....
---------- Post added at 04:35 PM ---------- Previous post was at 04:35 PM ----------
There's a hold button, what's that?
use the 20 or 200ohm setting
hold shouldn't make a difference in resistance readings, but leave it off so it shows real time resistance
I don't have a 20 option, so it's on 200, still nothing, it has a one sign way left, if I put it to read anything else on something it does, just not the ohms part
I just tested it again on my speakers, and it read them, but with the subs it only reads on the 200m side but I also think that's measuring volts, it jumps from .1 to .3 on that setting
"1" does not always mean over value. on a cheaper dmm, it means open line.
My meter displays "OL" but i have several cheaper models that display 1.
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
507
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
526
brafferty
brafferty
idaho
twizt3dfuc
