The camera opens in first gear
  • 3
aleksandar095
CarAudio.com Newbie
Serbia
I have problem with multimedia 7010b. I don't have a camera and when I put in first gear and start driving, the blue screen of the camera opens and closes when I drive faster than 20km / h.
This also happens when I put it in reverse and start driving backward. I think it should opens camera when I put in reverse... not after start driving.
I have checked settings and there is no option to disable camera?
How can I fix this?
Looks like a typical Chinese head unit. And most likely unless you can modify the firmware then no. Should be a wire hooked up that powers that up though possibly in the back look at the head units wiring chart it should say it possibly.
I have checked cables and there is 7 wires. One is missing. I have checked manual and I can see that there is no pink wire... that is for reverse camera. Is there any solution how to update firmware, or just unlock developer tools?
Hi, I installed a new Kenwood dnr476s head unit along with idatalink maestro Rr, the HRNI1, the HU-Ken1, and the nav1 adapter. It works well...
It only works when the car is in reverse. Also, some units have trigger options in the settings menu.
595
Try to reset again and if that doesn't work, try updating the firmware. To update the firmware for Alpine X800D, you can follow the instructions...
How positive are you that the reverse camera power supply was spliced in with a reverse light wire? If you used one of those blue wire splicers...
That looks like it can work for backup cam for sure, thanks
932
aleksandar095
CarAudio.com Newbie
aleksandar095
Serbia
aleksandar095
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
