The important parts?
sackamous
Ok my godchild has two 15" he2 subs that will play nothing but high bass. He has them in a pre fab ported box on a 800 watt peak kenwood amp. Just ordered him a candence 7000d so power prob solved, now what to do about this POS box! I'm sure we will build him a new one but I'm not sure were to start. It's going on what use to be the back seat of a ranger. I found some specs on the subs but not sure which ones are important for box size/frequencies. I'm thinking subs up port forward. Is PVC good for ports or would the big wood ones be better? I found a box calculator on re audios web site. You put in your box size and it gives you volume a frequency. If I knew what those numbers needed to be I could figure out the box. Oh should it be a common chamber or two seperate?
sub up port back, pvc will work or u can do sono or areo's. u can just do one camber talk to ram on here for a box plan u can have him draw one up and u just do the cuts and glue and screw it together. u have to factor in all of the sub specs lets just throw out 6 -7 cubic feet tune to 32 that would b great. prefab 15 box hmmm tune to like 44 not good. u need some basic tools to get the job done.
So about 3.5 a piece. Ok a found a formula for tuning a port. Should Plan to build the box to 4 cubes then I take out sub displacement figure out the port length and once that's in there the left over should add up to 3.5 cubes right? I know it won't be exact but what I'm saying is when it's said and done the left over room in the box would need to be 3.5ft^3? Or should I start at 3.5 with the inside volume before the port and sub?
I'd persoanlly do something like 7-7.5ft^3 tuned to 32-33hz. Subs forward/port up, subs & port up, or subs forward/port side will be your best bet with an ext cab truck...just depends on a lot of variables as far as what will work best.
If it's ok with u guys I'd like to give it a shot my self. I'm going to pull some meAsurements and play with sketchup for a while see what I come up with. Then I'll post it here for a numbers check make sure it's right. So 3.75 cubs a piece how much port area do I need I know the length adjusts the response, but how much area should the opening have?
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
4
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
3K
  • Locked
Looking to sell two ZX 1500.1 not working lots of good parts that are hard to come bye as well as a ZX 650X4 Also not working lots of good parts...
Well..How about those Shoes?? High Heels?? Dresses?? Never room in the closet for my stuff. Ya.. Use the Guest Closet???? :LOL: :LOL: 💩...
21
3K
Right now I have D2 and D1 options. In about month and a half I have a sh*t ton of parts that should be here. 4" coils should be in that bunch. I...
39
4K
sackamous
sackamous
Eunice, la
sackamous
