!!!!THE NEW BUILD 8 8s 4000RMS!!!!
^^^Yeah but the 802 is a high current amp made to run at low impeadances so I can see that.I am just saying that the HK line isn't bad just cause it has the MA Audio name.
to bad they light on fire @ low impedances. This guy i know used to run 2 off 4 hc2400's, used to turn those amps in on warranty all the time. I think 3 or 4 of them caught fire. Voltage still dropped into the 11's as well.
Yes they are known to catch on fire I have heard.But I thought it was from low voltage.I have heard them smoke and still play as well.
it is becuase of low voltage. what i'm trying to say is there so inefficient that at low impedances you need a REDICULOUS electrical. He had 2 hc2400's per amp + a h.o. alt and was still dropping far enough to burn them up.
2000lade has his off a ton of powermasters 16v's(10 or something) and caught it on fire.
it is becuase of low voltage. what i'm trying to say is there so inefficient that at low impedances you need a REDICULOUS electrical. He had 2 hc2400's per amp + a h.o. alt and was still dropping far enough to burn them up. 2000lade has his off a ton of powermasters 16v's(10 or something) and caught it on fire.
But he tryed to play .33 on music.I know what your saying and I'm not in disagreeance.there are more effecient amps but just because it says MA doesn't mean its crap.
true... //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
i know what your saying. i was just focusing on the 802.
Can you stop screaming !!!!!!!
Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
933
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
875
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
7
947
MEMPHISFLEX
MEMPHISFLEX
Chicago,IL
profundus-sanus
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
