The SSA 10" DCON subwoofer's TSP
  • 3
TheBassDr
11
Utah
DCON 10 Sound Solutions Audio 10" 300W DCON Series Subwoofer - SSA STORE
^Here's what it is^
I just wonder if the Sd can be anywhere near accurate. The Sd of my two 10" subwoofers is about 78in^2 or . I would like to give them a try because of the nature of their Theile-Small parameters and how well they seem to fit into a 1/4 length transmission line's needs. i.e. the low Fs, Qms& Qts are within the recommended range, and the 121.65in^2 Sd. Hopefully i'm not just misinterpreting this and there is truth to their ratings.
The site shows the sd to be 309cm^2 or 47.89in^2. Where did you get 121.65? That would be between a 12 and...maybe around a JL 13.5.
121.65/3.142 = 38.71
sqrt 38.71 = 6.22
6.22 * 2 = 12.44
The 47.89 comes up to around 8 inches which would be about right for a 10 inch sub. In any case, if your 10s are 78 or 39 each it would be a little more area for you.
Guys, let me know if I am off on anything here.
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
4
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
TheBassDr
TheBassDr
Utah
dacheatham
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
