Thin Amp Under Seat
Memphis has an "S" Class of amps that are very thin and use a small footprint. They are 2 and 4 channel if I am not mistaken. Worth looking at.....
I have a small footprint HiFonics Eagle (Black Heatsink) 4 channel that may fit your needs. It worked great under the seat of my Civic. 50 x 4, 80 x 2 or 160 x 2. Built in high/lowpass crossovers. 40 amp fuse. Adult owned, non-abused. Slightly taller than 1.5". It's dimensions are: 2" H x 8.74" L X 7.6 W. 65.00. Send me an e-mail if interested. spectre574@hotmail.com
Stetsom 4120
Channels 4
Potency PMPO 1800W
RMS Power @ 13.8V
STEREO 4 Ohms 4 x 80W
STEREO 2 Ohms 4 x 120W
BRIDGE 4 Ohms 2 x 240W
Consumption 0,6 a 56A
Input Tension 13,8V
Frequency Response 15Hz a 50KHz
Signal to Noise > 90 dB
Input Sensitivity 0,2 a 6V
Total Harmonic Distortion
Input Impedance 50 K Ohms
Output Impedance STEREO 2 Ohms
Output Impedance BRIDGE 4 Ohms
Damping Factor > 400
Lo Pass 40 a 700Hz
Hi Pass 70 a 700Hz
Dimensions 45 x 240 x 422 mm
Weight 3,6 Kg
I personally use this amp in my wifes car for over five years its very thin and is wired at 2 ohms front and 4 ohms back. Never had a problem and is a great amp
189
389
486
  • Locked
773
soulnomad
i has free bikes.
soulnomad
Richmond,VA
SPLaudio
