Time Alignment question
  • 3
Renzone3
ATLien
Ok,so I'm tweaking the TA on my Headunit(Alpine CDE-HD149BT),and I just want to know if I'm doing this correctly.I have a set of 6.5 components up front,and 6.5 coaxials in the rear fill.I measured the distance of all the speakers to my head except the furthest speaker from me which would be the passenger rear speaker which I left at 0.Ok,from there I measured the distance of each speaker to the furthest speaker(passenger rear),and subtracted the difference with the individual measurements of each speaker I had made when measuring the distance from my head.Rear passenger remains at 0 since it needs to be the first that reaches my ears.Make sense?Am I doing this right?Im not doing 3 way TA just passive of that helps.Any input would be appreciated.
What equipment are you using? It can be done physically (placement of sub), electrically (reversing wiring), electronically (DSP). If your amp has...
8
882
Exactly. Anything to get more frequencies coming from one source/area makes a big difference.
7
Yes it is, it has significant difference. I replaced my Mercedes head unit with the pioneer dmh-z5350bt, and I noticed that the built-in amp on...
10
Renzone3
ATLien
Renzone3
Fairburn,Ga
dumple
Decebal
    Jun 10, 2024
