Time for new components
sstumpf
Well its time for some new components up front. One of my diamond d6 blew. So What would be something comparable to the D661's I need a 6 1/2" speaker. I will be running off of this amp http://www.sonicelectronix.com/item_...o-D6600.4.html
I just want something as good as the D6's that will sound loud and clear. Also what is the difference between aluminum and silk tweeters? I have the aluminum right now. Thanks for your help.
When you have a choice between aluminum and silk tweeters, like Diamond gives you, the aluminum tweeter is probably going to sound brighter and more aggressive than the silk tweeter. That's the most simple way to describe it. I prefer a metal dome tweeter, when it's done well, because I think it sounds more like real music. That depends on good quality recordings as well.
Do you have a budget? Are you going to make new mounts?
Would like to use same mounting holes in a 02 silverado. Fronts take 6.5" speakers and the mounting whole is just under 6".
As for budget, Nothing too much maybe a couple hundred. But I do want quality.
Yes, I would like to stick with diamond. Always have liked them, And im running a D6 amp anyway. Those D663A look good. Might go with those if I cant find a good deal on something used. What do you guys think about those Diamond Hex?
id go cdt or phd.
Diamond Hex will crush anything those 2 brands could ever dream of offering. Those are just simply nut hugged brands.
---------- Post added at 06:24 PM ---------- Previous post was at 06:23 PM ----------
The letter at the end of the model number designates tweeter material. It will either be an A or S. A for aluminum S for silk.
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
In the $600 range I like my stereo integrity speakers so far Tm65 midbass $399 m25 tweeters $199
8
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
Hell... Run It!! If it sounds good to you. Then that is what matters the most.. Your OWN EARS.
6
sstumpf
sstumpf
Fisher, IL
sstumpf
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
