Tips to avoid getting jacked
This cable is 15' long it goes thru the trunk roof , thru the trunk, under my rear seats and a metal pipe goes though the loops with padlocks. I also have an alarm with a lcd to alarm me if I'm broken into. If anyone does try to open my hood it will open up about 3" buahahahahahahahahahhahahahaj
Thats pretty sweet ...
I like that idea but what if they have some big wire cutters? It is still possible for them to still break in and steal something within 2 minutes. By the time you come outside and check, they are already gone.
I don't think they'll be prepared for me - they like to be in and out quick - obstacles will make them just skip you. Anyway I only have a 10" and 2 amps - nothing too crazy
what happens when they just slide that metal bar out..
No tilt sensor... Shiiiiiit two tow hooks hooked to my truck and im taking your car for a ride till i have a place to break it open.
Sent from my draconis using Tapatalk
Let's be realistic though , I'm in a big city - too many eyes and ears for that . Thieves out here are quiet and not seen or heard.
There are holes drilled through the bar and the locks go through the bar and through the loop. It's not an easy jack move.
ah ok thats different then, didnt see the holes
They cut cut through locks but they'd need a bolt cutter and that not a common tool for a stereo thief. I'll say this, since I put this together I sleep much better at night .
Record a message played on a loudspeaker mounted under your car that starts with a demented laugh and then has a voice that says "Im coming to f*** you." Then have it go back to laughter. Have another speaker start playing the sound of a woman screaming. Just as that starts, your air horns start blaring and a blue rotating cop light starts flashing. Bonus points if you have a red strobe light in the car that starts flashing with no fixed interval. Have the brain hidden behind the passenger airbag or instrument panel, and have one that sends a remote message warning you that your car is being messed with. Maybe a couple of those handheld piezo sirens that you pull the chord on to activate. As you approach the car pull the chords and throw the sirens in a couple of directions (before they see you). I would only approach the car if it was one thief, he didnt see me, and I had a gun I knew how to use. Attacking with pepper spray is too risky, and more than one thief what if they both have guns?
Anyways, great advice on this thread!
It seems to me the most effective way is to bring fear into the equation- fear of getting caught, fear of the sick angry owner who just so happens to likely be a sadist, etc. A veteran car thief is pretty much immune to this- best way to avoid him stealing your equipment is to have a plane jane car with no stickers and as stealth an install as you can manage.
Dude I almost pissed myself lmfao.
So far I only have 5% tint all around (except windshield) but I have a friend that works on legit cop cars and hes going to hook me up with a badass alarm soon for a sweet price. (Same guy that got me the 5% tints)
Here's my car - I try to make it look normal but then rims might get some attention. No tints, no stickers, no drop kit on the car. Just a lil Honda on some cheap rims
And here's my van, does have tints but the rest is stock. A bit of an eye catcher to gangbangers and blacks . in Chicago they love these old Chevy vans but they usually put the 24" rims etc etc - so far so good and no break ins
Looks like a rough neighborhood. I can see why you're so worried about security.
There's even spray-painted graffiti on the sidewalk and the pole by your car //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Wat [emoji23]
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
6
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
3K
80INCHES
EPICENTERGLUED 2 ME
80INCHES
WESTCHESTER, NY
chillin
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
