Tired of trying to find pure sub signal...need help!!!
  • 3
I have already posted a thread on trying to find an unfiltered signal in my stock system for a subwoofer. With no success, I am looking for recommendations on a Southern California audio shop that has the skills/experience to do the job.
I have a 2015 Chevrolet 2500HD with Bose audio. I want to keep the stock amp to keep the features it supports but want to power a 12” sub off an aftermarket amp. When I sent the signal from the existing sub to a signal processor, amp and finally sub, I found the signal to be heavily processed for the stock sub configuration.
There appears to be a 35hz subsonic filter in the stock system. I attempted to find an unfiltered audio signal for the subwoofer every way I could think of. Post amp and even pre amp signals were all processed.
Realizing that the HU likely does the audio processing I realized I am looking for a solution outside of my skill set. Because of this I am asking for recommendations of audio shops that have strong technical skills when it comes to working to keep the stock interface.
Thanks for the help and recommendations!
If the headunit is doing the processing then the only way to get around it is to get a new headunit or a something like the miniDSP with summing capabilities.
Probably this. I doubt there's anybody that could get into your factory head unit and pull some RCA outputs out of there pre-processed.
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
560
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
3K
tank313
tank313
Los Angeles, CA
hispls
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
