To Start Again... Or Not?
  • 1
nates
Hey All,
I have a 2005 Silverado with a box under the back seat that came with the truck. It's got 2 12w0'-8's in separate sealed chambers at .9cf each. There are several place where screws have been run through the wall of the box (mounting amps and such to it), but I think they all have screws filling the holes, so no open holes. The amp on these is a infinity reference 611a which pushed something like 450wrms at 4 ohms (current overall impedance). Which as I understand is way over the 125wrms these subs are rated for. The box chambers are also .4cf too small for this sub if my research is right. I'm pretty unhappy with the sound overall, it's not very tight, and I can't seem to find any sort of sweet spot with it. Just kinda muddy and flabby (my best description).
I'm thinking of just scrapping the whole thing and switching the subs and box out for a single ID10 on one side (lets me use the other side for storage which I'm lacking right now). Run at 2 ohms that should catch around 500wrms from the same amp, and would be in an enclosure around .7-.8cf.
Just getting back into car audio again, and the last sub I had was a Focal Polyglas in a sealed box which I loved, I suspect the ID10 may be a little closer to that than the current 12's I've got.
Am I going down a good path, you think, with the ID10, or does anyone have another suggestion.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
That's what I'm going to do, cheap, and easy to do. I picked up a spst switch today
I found a solution that you may try. PAC TR-4 Remote Turn on module. It's on Amazon for about $17.00
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
nates
nates
Ventura, CA
nates
