toyota camry wont start.....alarm killswitch??
  • 3
Donks
CO, Ohio
My sister has a 95 toyota camry. shes had an alarm put on it last year and up until yesterday it just stopped turning over. when i turn the key. no response, all lights on dash and radio work, good battery voltage, starter...etc I beilive it has something to do with the aftermarket alarm she got put on it last year has finally went FAULTYcause its never had this problem. it locks when its supposed to unlock and unlocks when u lock. and when you unlock and open a door alarm goes off. obviously its faulty, so my quiestion is how do bypass it to make it start again? because ive tried disconnecting alarm and that doesnt work....//content.invisioncic.com/y282845/emoticons/pissed.gif.9f665f96bc89e98e708dabd4580bb591.gif
the alarm is called ASTRA 777. Here is the manual for it - http://www.scytek.net/manuals/astra/a777.pdf
usually the starter wire is split with a relay. it seems like it was normally open (disconnected) unless disarmed (which it's supposed to reconnect). reattach starter wire (it should be the only wire cut down there) and bring it to the shop and tell me to fix their ****.
my ma had the same problem, there was a switch under the dash on the driver side. caused the symptoms that you are talking about
typically the SWITCH issue is when the car won't REMOTE start, not start period (the switch is a neutral safety switch).
the switch cause the car not to start period. also caused the alarm to go off when you unlocked the car.
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Thanks everyone. Good info. I don't think I want to go above $150-$200, considering its a 2007 hybrid. Now I just have to find something to fit...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
501
Hey everyone! I'm a car stereo newbie and I know next to nothing about car stereos, only features. I recently purchased a 2010 Toyota Highlander...
Donks
Donks
CO, Ohio
NFrazier
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
