Trunk box advice
  • 1
DeuceLoco
CarAudio.com Newbie
AZ
Trunk box advice needed....At the moment I have my subs and ports facing rear but still have a few inches on top and on sides of my actual box so I still get good bass into the cab. The problem is one of my SDRs blew and i am looking to upgrade my subs to 2 12s DDX or EVL (unless there is something better for under 200 per sub) but would need a larger enclosure and it would sacrifice those extra inches of space I have for the sound to still travel to the cab. Its not "sealed" but still worried about too much "bass blockage" what would be the best box to go with.... 4th order, sealed facing forward, 2 seperate ported boxes facing rear or facing eachother with a space in between them for more bass to enter the vehicle? Etc I am looking for that perfect medium with both SQ and SPL
I'm looking for 4-5 cubic feet depending on which route i choose
Ps. I drive a 2019 Impala so its a big trunk and i always leave my rear seats folded down so that ia not a problem
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
748
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
DeuceLoco
CarAudio.com Newbie
DeuceLoco
AZ
DeuceLoco
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
